XCeed Pro Ceed GT Lenkrad Umbau
Umbauten im und am KIA Ceed CD (Motor, Getriebe, Fahrwerk, Räder, Karosserie, Interieur).
andreas87 Sa 4. Feb 2023, 15:44 InterieurLenkradUmbau
acbw132zug
10. Apr 2024
14
Beitrag14
andreas87 hat geschrieben:
Mo 20. Feb 2023, 18:13
Und ja es geht !!!
Habe das Kabel gelegt.
Hello bro,
Does English work for you? I’m a ceed SW 1.5 tgdi owner from Taiwan.
Currently I did the same thing like you but a little bit different. I used the kia K5 gtLine steering wheel with shift paddle but using the original function buttons and harness. I cannot use the one come with K5 steering wheel together since the K5 function button doesn’t have the same layout like ceed.
What I already did was cut off the paddles wires and already connect them the each side of clock spring.
I tried to connect the wires to the shifter but I think I found the wrong wires and shift got no feature now. My shift paddles got 2 wires each, I think the yellow one should be connected to common line, is it GND? I’m not familiar with the canbus or none canbus system.
It will be very helpful if you can give me some guide to made it working. Thanks.
acbw132zug
10. Apr 2024
14
Beitrag15
BTW, I believe that it’s possible to get the right wire from the shifter as well.
Can you share the shifter connector definition with me? Many thanks.
78
Beitrag16
Have you read the entire thread?
acbw132zug
10. Apr 2024
14
Beitrag17
Fr 12. Apr 2024, 15:14
Hello, I'm using google translator, maybe I miss something? I just tested and confirm that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
acbw132zug
10. Apr 2024
14
Beitrag18
acbw132train hat geschrieben:
Fr 12. Apr 2024, 16:11
Hello, I’m using google translator, maybe I miss something? I just tested and confirmed that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
Hi Bro, I think I understand now. Now the only thing is if mine EM11 pin definition(1.5 tgdi) same as yours(1.6 tgdi). Basically I think it would be the the same.
Can you mark out where is 34 and 12 hole of EM11 for me? I will check mine. Is the wire color same as the one mentioned in the diagram(Green and Pink)?
Many thanks bro.
78
Beitrag19
See at the Picture. You need two new cables to the steering wheel column.
acbw132zug
10. Apr 2024
14
Beitrag20
Fr 12. Apr 2024, 21:03
Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I complete👍
acbw132zug
10. Apr 2024
14
Beitrag21
acbw132zug hat geschrieben:
Sa 13. Apr 2024, 02:31
Hello bro, it works! Thank you very much!
BSB-Coolio
Ceed (CD) Platinum Edition
09. Jun 2024
Beitrag22
ich habe mir ein GT-Line Lenkrad in meinen Ceed Platinum BJ 2018 eingebaut.
Das ich ohne das vibrieren leben muss ist in Ordnung, aber seit dem Umbau funktioniert mein LKAS nicht mehr.
Die Anzeige im Display wird bei erkennen der Strassenmarkierung zwar grün, wenn ich aber ohne blinken den Mittelstreifen überfahre,
kommt kein Lenkeingriff. Was kann das sein?
Sonst funktionieren alle Tasten korrekt
78
Beitrag23
servus,
besitzt das lenkrad schaltpanels?, wenn nein wurden die kabel für den haptikmotor ausgepinnt? Thema Kurzschlussgefahr!
acbw132zug
10. Apr 2024
14
Beitrag24
Hi bro,
Currently I'm working on illuminated door sills which got led. But after testing the fuse on ICU I can't find one suitable. And since I don't have circuit diagram. Can you help to point out on which connector and which wire can I get the 12v triggered only when the door is open? Thanks in advance.
acbw132zug
10. Apr 2024
14
Beitrag25
Di 24. Dez 2024, 10:22
Hi bro,
BTW, it would be very helpful if you can help to point out connector location as well, thank you very much
acbw132zug
10. Apr 2024
14
Beitrag26
Mi 1. Mär 2023, 22:55
Pinto hat geschrieben:
Mo 27. Feb 2023, 17:40
Respekt für den Umbau bei einem nicht VW-Produkt, da traut sich nicht jeder drüber... :saluting_face:
Bei Kia geht leider nichts mit programmieren.. Wollte die Start/Stop und auch den standartmäßig eingeschalteten Spurhalteassistenten deaktivieren, trotz Connections keine Chance...
Hab mal paar Gedanken gehabt zu der Start/Stopp und dem Spurhalteassistenten.
Hier siehst du an der Start/Stopp den Schalter und die Steckverbindung unter der Konsole.
Man könnte also zum Beispiel ein Arduino Nano zum schalten des Signals verwenden. Quasi immer wenn Zündung angeht und die LED am Schalter aus ist dann einen Impuls geben um die Masse zu schalten dann würde der Arduino immer wenn Motor angeht den Schalter betätigen und die Start Stopp wäre aus.
Man kann die Stecker bestellen und einen Y Adapter dazwischen machen. Ebenso kann man dann den Arduino sagen wenn ich trotzdem den Schalter betätige dass die Start Stopp wieder aktiviert wird.
Das selbe Prinzip würde auch für den Schalter des Spurhalteassistenten funktionieren.
Gibt es auch fertig hier zu kaufen:
https://www.carelectronic-webshop.de/ca ... odul_14_17
Hi bro, can you show the circuit for the lane assistance button on the left hand panel as well? Just successfully disable ISG on start automatically with an delay relay module. And want to see if same idea can work on lane assistance button, thx.
  • Front Umbau Spirit >> GT
    von Jonas » » in CD: Tuning / Styling
  • LED zu LED Innenraum Umbau mit Glasdach
    von Soedboy » » in CD: Tuning / Styling
    15871
  • Wechsel zu KIA X-Ceed
    von Trebla09 » » in CD: Allgemein
    25411
  • Ceed JD Navi
    von Ceed2013 » » in JD: HiFi / Multimedia / Navi
    21739
  • Kia Ceed SW BJ 2018
    von Flikko » » in CD: Allgemein
    20754
