XCeed Pro Ceed GT Lenkrad Umbau
Umbauten im und am KIA Ceed CD (Motor, Getriebe, Fahrwerk, Räder, Karosserie, Interieur).
andreas87 Sa 4. Feb 2023, 15:44 InterieurLenkradUmbau
acbw132zug
10. Apr 2024
Beitrag14
andreas87 hat geschrieben:
Mo 20. Feb 2023, 18:13
Und ja es geht !!!
Habe das Kabel gelegt.
Hello bro,
Does English work for you? I’m a ceed SW 1.5 tgdi owner from Taiwan.
Currently I did the same thing like you but a little bit different. I used the kia K5 gtLine steering wheel with shift paddle but using the original function buttons and harness. I cannot use the one come with K5 steering wheel together since the K5 function button doesn’t have the same layout like ceed.
What I already did was cut off the paddles wires and already connect them the each side of clock spring.
I tried to connect the wires to the shifter but I think I found the wrong wires and shift got no feature now. My shift paddles got 2 wires each, I think the yellow one should be connected to common line, is it GND? I’m not familiar with the canbus or none canbus system.
It will be very helpful if you can give me some guide to made it working. Thanks.
acbw132zug
10. Apr 2024
Beitrag15
BTW, I believe that it’s possible to get the right wire from the shifter as well.
Can you share the shifter connector definition with me? Many thanks.
64
Beitrag16
Have you read the entire thread?
acbw132zug
10. Apr 2024
Beitrag17
Fr 12. Apr 2024, 15:14
Hello, I'm using google translator, maybe I miss something? I just tested and confirm that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
acbw132zug
10. Apr 2024
Beitrag18
acbw132train hat geschrieben:
Fr 12. Apr 2024, 16:11
Hello, I’m using google translator, maybe I miss something? I just tested and confirmed that not able to get the signal wire from shifter, can you show me the exactly 2 wires from the red connector that you posted?
Hi Bro, I think I understand now. Now the only thing is if mine EM11 pin definition(1.5 tgdi) same as yours(1.6 tgdi). Basically I think it would be the the same.
Can you mark out where is 34 and 12 hole of EM11 for me? I will check mine. Is the wire color same as the one mentioned in the diagram(Green and Pink)?
Many thanks bro.
64
Beitrag19
See at the Picture. You need two new cables to the steering wheel column.
acbw132zug
10. Apr 2024
Beitrag20
Fr 12. Apr 2024, 21:03
Thanks bro! I will try it out. I already added new cable but not yet connect them. Will reply the result once I complete👍
acbw132zug
10. Apr 2024
Beitrag21
acbw132zug hat geschrieben:
Sa 13. Apr 2024, 02:31
Hello bro, it works! Thank you very much!
BSB-Coolio
Ceed (CD) Platinum Edition
09. Jun 2024
Beitrag22
ich habe mir ein GT-Line Lenkrad in meinen Ceed Platinum BJ 2018 eingebaut.
Das ich ohne das vibrieren leben muss ist in Ordnung, aber seit dem Umbau funktioniert mein LKAS nicht mehr.
Die Anzeige im Display wird bei erkennen der Strassenmarkierung zwar grün, wenn ich aber ohne blinken den Mittelstreifen überfahre,
kommt kein Lenkeingriff. Was kann das sein?
Sonst funktionieren alle Tasten korrekt
64
Beitrag23
servus,
besitzt das lenkrad schaltpanels?, wenn nein wurden die kabel für den haptikmotor ausgepinnt? Thema Kurzschlussgefahr!
  • Front Umbau Spirit >> GT
    von Jonas » » in CD: Tuning / Styling
  • LED zu LED Innenraum Umbau mit Glasdach
    von Soedboy » » in CD: Tuning / Styling
    7186
  • Ceed JD Navi
    von Ceed2013 » » in JD: HiFi / Multimedia / Navi
    4115
  • Kia Ceed SW BJ 2018
    von Flikko » » in CD: Allgemein
    2972
  • Wechsel zu KIA X-Ceed
    von Trebla09 » » in CD: Allgemein
    9985
